Towel marks from waxing http://www-.luthiersforum.com/forum/viewtopic.php?f=10137&t=48544 |
Author: | FL6 [ Tue Nov 15, 2016 4:26 pm ] |
Post subject: | Towel marks from waxing |
I'm a beginner in terms of refinishing guitars, electric specifically. My issue is after wet sanding the laquer clear coat down to 2000, I then applied wax. I applied it by hand on both sides but somehow the towel that the guitar was resting on as I waxed has made an impression fairly deep into the finish. Was heat the cause? Should the guitar not be flat on a clean towel when buffing/polishing? The good news is on a test guitar I got my technique down when I changed to compounds and omitted wax but I'm worried about making the same mistake again. So I saw what happened but not sure why. Thanks. |
Author: | Alex Kleon [ Tue Nov 15, 2016 5:51 pm ] |
Post subject: | Re: Towel marks from waxing |
What kind of wax, Paul? Alex |
Author: | FL6 [ Tue Nov 15, 2016 6:23 pm ] |
Alex Kleon wrote: What kind of wax, Paul? Alex Mothers carnauba wax |
Author: | dzsmith [ Tue Nov 15, 2016 7:03 pm ] |
Sounds like the finish was not hard yet. |
Author: | FL6 [ Tue Nov 15, 2016 7:08 pm ] |
dzsmith wrote: Sounds like the finish was not hard yet. I wondered about that. I let it hang for 6 weeks but I did put a lot of coats on. |
Author: | Alex Kleon [ Tue Nov 15, 2016 8:42 pm ] |
Could there have been some solvent on the towel? That could soften the wax, even if there's a hint of it. Alex |
Author: | FL6 [ Tue Nov 15, 2016 10:35 pm ] |
Alex Kleon wrote: Could there have been some solvent on the towel? That could soften the wax, even if there's a hint of it. Alex I don't think so but now that I think about it, it was an old towel. I'll test a small area with a different towel. Thanks. |
Author: | B. Howard [ Wed Nov 16, 2016 7:45 am ] |
What brand and type of finish? |
Author: | FL6 [ Wed Nov 16, 2016 8:48 am ] |
B. Howard wrote: What brand and type of finish? Duplicolor clear coat. |
Author: | B. Howard [ Thu Nov 17, 2016 8:11 am ] |
Not to familiar with the duplicolor stuff but I have seen issues with other rattle can brands (most notoriously Deft) Taking months to harden and then never really achieving the hardness I would expect of a nitro lacquer. |
Author: | FL6 [ Thu Nov 17, 2016 8:31 am ] |
B. Howard wrote: Not to familiar with the duplicolor stuff but I have seen issues with other rattle can brands (most notoriously Deft) Taking months to harden and then never really achieving the hardness I would expect of a nitro lacquer. Yeah this is possible too. I'm going to wet sand and buff with compound and see where it gets me. Thanks. Edit: I think it's not hard. I haven't come across a hardness test but I noticed someone in another forum said to check if you fingernail can make a dent. Well mine did, I went easy so it's not deep but looks like I'm going to have to keep waiting. Is there a repair procedure for clear coats? Could I take it to a professional shop and have them add a few coats? The paint job is rather intricate, I would rather not start that over. ![]() |
Author: | B. Howard [ Fri Nov 18, 2016 8:11 am ] |
FL6 wrote: Is there a repair procedure for clear coats? Could I take it to a professional shop and have them add a few coats? The paint job is rather intricate, I would rather not start that over. ![]() IME the only solution is to remove the soft lacquer and re-finish. If you put a harder coating over a softer one it will crack and peel.... |
Author: | FL6 [ Fri Nov 18, 2016 8:43 am ] |
B. Howard wrote: FL6 wrote: Is there a repair procedure for clear coats? Could I take it to a professional shop and have them add a few coats? The paint job is rather intricate, I would rather not start that over. ![]() IME the only solution is to remove the soft lacquer and re-finish. If you put a harder coating over a softer one it will crack and peel.... So just sand down to the paint? |
Author: | Rockinrob86 [ Mon Nov 21, 2016 11:10 am ] |
It's going to be extremely hard to not sand through - I usually chemically remove nitro. what did you paint it with? |
